- Nov 21, 2005
- 827
BrotherBart said:Essentially that is what Hearthstone does with the Morgan and Clydesdale inserts. They are metal stoves with the firebox lined with soapstone bricks. I think ya could do that with any stove. Some will say that other stoves weren't certified with soapstone in them but I contend that they weren't certified with red oak burning in them either.
I don't know, the Clydesdale & Morgan are soapstone inside cast iron outside, whereas in this situation it would be cast iron/steel inside w/soapstone outside. I have the Clydesdale, when I see a firebox with firebrick it looks like the firebrick rests directly against flat walls. The Clydesdale, it's walls have air channels stamped into them that keep the soapstone floating so it doesn't have complete contact. I included pictures, straight from my manual I added the yellow to it, ignore the real arrows which are pointing to a couple allen wrench screws, and the back levelling bolt. The one I drew the arrows shows the air channels in the back, the one with the spots identifies each stamped pocket or bump to keep the soapstone from having full contact, there's more than is shown. I find it interesting the floor is big air pockets minimizing cast iron contact with the soapstone and the sides & back are the reverse, a lot of cast iron contact with a little bit of air channels. I don't know why they'd do that unless having the soapstone have direct contact was a problem. Hmm... this may answer the difference MSG and I talked previously and his soapstone stove prefers ash and mine doesn't. With all those little air pockets I have beneath my soapstone that's dead air space and insulation, he doesn't have it and his likes some ash.
I would think you could surround your unit with soapstone but keep some space at least, the steel stoves I've had in the past always started to warp a little over time, I think that's why every soapstone unit I've seen uses cast iron as their metal. As for having the soapstone allow direct contact, I'm not really sure about that. All the channels in the Clydesdale make it look like there's a problem having that configuration, not to say they didn't stamp all those pockets and channels and things for another reason, or maybe I've not been paying attention and firebrick units also have them.
