New Clydesdale owner here . . .
I've had the stove for a week.
Things are going well, however on two occasions the cat thermometer has registered "Too Hot" (just a bit), but the stove itself is nowhere near too hot. Using an IR meter on the stove, the hottest metal I can find is barely 400 (under the top grill). The flue (the small section I can see) is around 450. The glass is hotter (600+) but I'm not sure it's measuring the glass or the flame in the box.
I'm not overloading the stove with wood. The flames looks good and the secondaries are definitely putting out solid flame. In fact, I'd say at times there's more fire coming out of the secondaries than the wood itself. Built-in fan is on full.
When the cat registers too hot I close the air intake completely. It takes a while, but the fire will start to die down and the cat will cool off.
Any thoughts as to why this is happening?
And if it happens again, should I bypass the cat anytime it registers too hot.
Thoughts?
Thoughts?
