I’m in the learning stages of my new BK boxer. The dial for the cat is pretty self explanatory. However, the dial turns way past the low setting, almost making a full circle. On the highest setting the dial stops in the 6:00 position and the low setting is counter clockwise to the 12:00 position. For some reason the dial is able to go way beyond the 12 position before it hits a hard stop where it almost makes a 360 degree swing. The dial is tight and reactive when turned. I’m just curious if there is a reason it’s able to go way past the low setting.
![Cat dial question Cat dial question](https://www.hearth.com/talk/data/attachments/303/303984-2beba3f47b9a6c8c0c3596a5cefe05f1.jpg)
