Hi everyone.
When I got this stove last February (2018) it had problems right out of the gate dying a few minutes after successfully starting. I called tech support and they had me change the wires from one heat sensor to the other on the exhaust fan and from one vacuum to the other (yes my stove had two separate vacuum switches installed) on the opposite side. After that it worked, but there was little winter remaining and I didn't use it all that much until this season.
Just to be sure the stove would be okay Castle sent me a new vacuum switch and a new exhause fan at the beginning of March.
This winter it has been working okay. But I realized if I didnt thoroughly clean it before each use then there were other issues. So I bought a set of small and medium wire brushes and a dedicated shop vac just for the stove. And I thoroughly cleaned it before turning it on each use. I've also cleaned out the exhaust box a couple of times.
The results are the stove still looks very new inside and out and for the most part (depending on the pellets used) it doesnt take much to keep it clean.
Last week the stove started smoking more than usual and a few days later it started up with the vacuum problems again. I exchanged the vacuum switch with the one they had sent. No change. Took out the vacuum hose and checked it and the metal tube into the burn chamber. All clear. Tried using a jumper over the vacuum switch and the stove works fine. While it is running jumped, I checked the hose. There is no vacuum being created through the line. Checked the exhaust pipe through the side of the house and outside of the house and it is all clear.
I've also tested the different vacuum switches [all three of them] and with only slight suction they all work and close the contact with the wires on it. It appears the stove just isn't creating any vacuum whatsoever.
I'm at a complete loss. Has anyone else ever had this sort of issue?
Thank you for your help.
