TonyVideo
So are you saying that you get more heat from the p series? You'd stick with p
I looked at the XXV bought bought a P68 and P43. The P series does get hot on the outside if you are cranking heat On low you won't get scalded but know you will have touched something hot. I wanted as much heat into the room as possible even if the stove radiated heat on the outside. Check the install location distances of each stove to a wall as that may help in determining your choice depending on where you are putting it.
