elkimmeg said:
If you are going to burn witha modern wood stove you will have to modify your burning habits Modern stoves are not quick heat ups they are designed to be run 24/7
I was in much the same situation as sciencefan when I switched from a homebuilt simple steel box stove that I had been using for 12 years or so to the Drolet. I now have some time on the new stove and with some simple changes I can get the magnetic pipe surface temp to 600°F and climbing fast in 15 to 20 minutes, at that point you HAVE to be standing by the stove because 900° is only a few more minutes away.
By this time the heat exchanger with the blower on is making a lot of hot air even though the main body of the stove (fire brick) still has a lot of heat to soak up. If I have some time I will do up some drawings and a description of how I build the fire.
I do not think I want to take the temperature up much faster, thinking about the ceramic baffle plate. Just saying that the modern stoves do not have to be slow getting heat to the room.
Sciencefan I see you are in Maine you may want to check out the Drolet stoves, they are made in Canada so should be available to you. From what I have seen mine is a good but inexpensive stove. Record so far is a single load 12 hours with 1.5 inches of live coals left in the stove, covering the bottom not just in one corner
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
It did come with a broken glass in the door but they sent out a new one right quick. There was a bump of glue or something between the glass and the gasket that caused the glass to be bent when it was clamped in the door, temp changes and/or mechanical shock in shipping caused the glass to crack.
