After reading the responses on insurance options, I guess that I am looking harder into the Progress Hybrid. It seems to be designed almost specifically for my application. Questions for Progress owners -
With only the side door, how do you clean the glass, or do you just not have to?
Are those metal stakes behind the door to keep the wood from hiting the window, or are they fake?
Has not having any local support for these been an issue?
What is the life of the cat? Issues?
Has anyone purchases this stove before physically seeing one? I dont feel like going to NH just to look at it.
I am guesing that it has no fan but I am not sure.
I am also concerned about setting a 700lb stove + the hearth pad in the middle of my dinning room. The basement below the stove is finished and I fear the drywall will crack, or worse. The six month trial is very tempting but I would then have to wait until fall, and pay more because they will not be on sale. $2500 for what you get with this stove seems like a great value.
Mike: I own the Progress, and Like Dennis said, I replaced a Fireview. I think my answers match Dennis' but here you go:
1. I do have to clean the glass every so often but it is not hard. I use extremely fine steel wool (per WS recommendation) - it's not difficult to acces from the side door.
2. Those Andirons (metal stakes) are to keep wood from hitting the glass. They are not fake.
3. Not having local support has never been an issue. Woodstock is patient and will not rest until you are satisfied.
4. The cat has been replaced with a stainless steel substrate rather than ceramic. There were reports of early failures with a small number of the stainless cats (including mine) but WS sent me a new SS one which has been working fine, and they are working to understand and correct the failure mechanism. They have even provided me with timely updates.
5. I saw the stove before buying it. I was impressed with the rugged construction, especially the concept of a steel firebox surrounded by soapstone panels.
6. There is no fan. I heat a 2300 sq ft house. This was a mild winter, so not a good test, but I can say it heats quicker and better than the Fireview. I really think this stove actually throws more heat than the Fireview while using less wood. Others have reported the same.
I was worried it would not work well for shoulder season, but I was proved wrong. It is a bigger stove with more stone than the FV, so I figured it would take longer to heat the house. It's actually quicker to get to temp than the FV for a couple reasons. First, the Combustor bypass is not directed straight out of the firebox and up the flue, like in the FV. Flue gasses are forced to take a longer path through the chamber below the lid, which warms up the cat quicker and generally helps to get the entire stove warm quicker. Second, the basic construction of the Progress is a steel firebox with soapstone panels on both sides directly in contact with the steel. The FV was two layers of soapstone separated by a thin layer of air. The air layer in the FV (I am convinced) slows down and even tempers heat flow from the firebox to the outside shell.
I am very happy with the Progress.
