madrone said:I've got one across the room from the stove on the wall by the staircase leading up to the bedrooms, and one upstairs in a bedroom, (to compliment the 7 smoke detectors.) Seems like that should cover both the wood stove and the NG furnace. I bought one after my original oil furnace cracked its exchanger and started leaking flue gases into the ducts. Wish I'd had one before it happened. We were fine, but I might have figured out what was going on sooner.
That said, I've always considered the furnace the dangerous one. I've seen it suggested here, and had the thought myself, that the smell of wood smoke in the house would likely accompany any leaking of CO into the living space. Anything to that, Jake?
ckarotka said:Mount the CO detector near the floor. CO is heavier than room air and will concentrate on the floor first. A ceiling mounted one will provide interesting thoughts of why it didn't go off when your lying on your back staring up at it.
ckarotka said:Thats why it has a plug on it, to get it closer to the floor. It's the manufacturers why of getting them off the ceiling. The plug is a battery back up....Yes? Smoke detectors don't have plugs but can be hard wired. I'll stick with what I was taught and seen.
Dakotas Dad said:ckarotka said:Thats why it has a plug on it, to get it closer to the floor. It's the manufacturers why of getting them off the ceiling. The plug is a battery back up....Yes? Smoke detectors don't have plugs but can be hard wired. I'll stick with what I was taught and seen.
LOL, ok stick with it...
from the manual for 1 of my detectors:
120v Battery backup
Recommended Installation Locations
CO alarms should be mounted in or
near bedrooms and living areas. It is
recommended that you install a Kidde
CO alarm on each level of your home.
When choosing your installation locations,
make sure you can hear the
alarm from all sleeping areas. If you
install only one CO alarm in your
home, install it near bedrooms, not in the basement or furnace room.
• When wall mounting, place out of reach of children. Under no circumstances
should children be allowed to handle the CO alarm.
• Placing the alarm at eye level allows for optimum monitoring of the
digital display.
and for the other one, battery only:
Where To Install Your Kidde CO Alarm
The following suggestions are intended to help you with
the placement and installation of your Kidde CO alarm.
• Place out of the reach of children. Under no circumstance
• Install in a bedroom or hallway located close to the
sleeping area. Take special care to verify the alarm can
be heard in sleeping areas.
• It is recommended that a CO alarm be installed on each
level of a multilevel home.
• Locate at least 5 feet away from all fuel burning appliances.
• Placing at eye level allows for optimum monitoring of
the red and green indicator lights.
bostock said:when did the CO detector thing get going? I only ask because as a kid growing up (70's and 80's), we burned all through the winter (Upstate NY) and so did all of our neighbors, friends, family etc...never even HEARD of a CO problem, or even a CO detector. I only jumped back into the woodburning world recently and it just seems that, while we all know CO can kill, of course - how likely is it to have probs with our woodburning? Don't get me wrong - i'm buying two detectors this weekend but, i think there may be some smoke/mirrors within the industry too. I won't challenge it, because i have a family at home - but i think there is a little bit there.
That's not true at all. To have smoke the fire needs to be in the pyrolysis phase, which at the same time you are going to be producing plenty of heat to maintain a good draft so the chance of CO in that phase is pretty low. On the other hand in the charcoal stage the fire produces huge amounts of CO but doesn't produce anywhere near the same heat so the draft is significantly reduced and it wouldn't take a lot wrong to get it flowing in reverse and filling the house with scentless deadly invisible fumes.madrone said:I've seen it suggested here, and had the thought myself, that the smell of wood smoke in the house would likely accompany any leaking of CO into the living space.
Safety is a form of natural selection. Those who don't believe in it will eventually be deselected.SteveKG said:it is a different attitude and different world.
