We are in transition, now. The two dehumidifiers in the basement still occasionally kick on, a little less each week, they're set at 55% or 60%. But starting two days ago, I fired up the humidifiers on our upper floors, as we were running about 35% RH and I like to keep it 40% to 50%.Ahh opposite worlds. My dehumidifier is still running
We have a full basement with 8 ft (2.44 m) ceilings under the 1775 part of the house, in fact a third of that is the original 1734 house ground floor / kitchen. Then 6 ft (1.83 m) ceilings under the 1890's addition, and a 4 ft. crawl space under the 1990's addition. Dehumidifiers in each section.I also would have thought the stone would retain humidity but no, I imagine you have a crawl space at the base of your house,
82F (28C) in my office, due to high-power computers and that being the location of one of the stoves, but more like 73F (23C) in the rest of the house. Obviously, the office couch is where everyone wants to pass out in front of the TV, tanning themselves just ten feet from the stove.however your very low RH percentages make me think of very high internal temperatures 😂
The trouble is the denominator... cubic meters. If you have a 6000 sq.ft. house with varied 7 to 14 ft ceilings, that's maybe 1500 cubic meters, or 15,000 liters of water at 23C for 50% RH.I found this graph, how much water can 1 cubic meter of air contain, can help understand how many liters give to the house
thanks for your contribution, I often see these tea pots, I've never used,I have a tea pot on mine, doubt it helps, but I have it, why not use it? Its cast iron, on a trivet.
hah... I see it now. Grams! I was using 20.4 L/m3 saturation at 23C, but it's only 20.4 mL/m3! What's 1000x difference? lol...@Ashful
It's very hot there! I planned a sofa, which I actually still have to buy, less than 3 meters from the stove, now I realize that it won't be useful for me, I don't really like excessive heat, unlike my wife. However, I think the calculations you made are wrong, reporting everything in meters, approximately, if you wanted to bring humidity to 60 percent (this is an example) you would need 3-4 litres humidified in addition to what you have in the air now. Your house has approximately 1800 cubic meters, 50 percent at 23 degrees, you have about 18 liters of water in the air, currently.
My house heated by this stove has only 200 cubic meters, 1 liter of water more in the air makes a lot of difference.
Yes. I have the same trouble, living in an old (for America) stone house with traditional windows. We can get a lot of condensation in and around windows, if we get too overzealous with our humidifier settings or placements. But most other American homes are newer, framed, and pretty well insulated by comparison to much of what I've seen while traveling in Italy.Condensation, must also be considered,
especially here ( house poorly insulated )
if there are cold spots, humidity will condense in those points, creating visible water and mold, and therefore it is necessary to consider it in the choice of desired humidity.
Yes, I suspect things were different. We were an agricultural society, scattered far and wide on farms often located some distance from cities and ports. Getting sufficient amounts of specialty materials like mason's lime from the closest lime kiln to these farms would have typically required multiple prohibitively-expensive journeys by ox cart in the 1700's. As a result, rather than using even the basic lime-based mortars available at that time as bedding mortar, they would often dig their own sandy clay (no Portland, no lime, no gypsum) on-site, and use that as bedding mortar. I suspect this type of bedding mortar transports a heck of a lot more water up through the wall than the lime-based mortar used in cities (or Italy) at that time, and way more water than the Portland mortars that would come along in the 1800's.@Ashful
You saw right, however, cement also has two faces if the plaster is very greasy (rich cement) it will behave almost like a latex
plaster should have an ideal percentage for to breathe, and then obviously the exact paint, at least this I know, then it's clear Italian and American are totally different construction techniques.
