Hi all, thanks in advance for the help! We just got a new Jotul F55v2 stove, and can't seem to get a fire started without filling the whole house with smoke.
It seems like it just doesn't draw at all until the whole stove and chimney get heated up, so in the initial stages when the fire gets lit the stove completely fills with black smoke which leaks out anywhere it can including the air intake and the seam of the exhaust pipe. Then if we open the door to add more kindling or wood, huge amounts of black smoke pour out into the house.
Not good.
Once a fire has been lit and the stove and chimney etc are all going well, things seem ok, and the stove can burn with the door open while adding wood and little or no smoke comes out.
Stove is a Jotul F55v2 with a rear vent which exits the back of the stove horizontally and goes through a thimble into a lined chimney that is ~25ft high. The outside of the chimney has an access hatch for cleaning which is not airtight it just latches closed, I don't think that's the problem but I'm mentioning it.
Super frustrated and looking for any help! Thank You!
best
-N
Not good.
best
-N
