I'm not familiar with this stove, but does it have a switch on the hopper lid that prevent the auger from turning if not closed?
			Does this stove have fuses. Dont know if this was mentioned yet. My auger jambed last year and blew the fuse. the stove was 1 day old so had the dealer come out. Replaced the fuse and worked ever sinceHouse voltage. Somewhere between 110 to 130 volts.
I'd also go looking for a loose connection in the lines going to the auger and to make certain the high limit snap disc isn't tripped, reset it if it is. There is usually a red button between the terminals of the manual reset snap discs with the power off and the stove unplugged press the little red button if it has tripped the button will go in and click.
That led bar has 5 lights behind it starting at the bottom is 1, above it in order are 2,3,4,5. If the middle light (#3) was on you had an open hi limit snap disc and the auger's power feed was shut off.
Can I jump the snap disc like I did the vacuum switch?
