Thank all of you guys for the input and opinions.
I'm getting older and can't swing the 'ole maul like I used to, so I have been looking at fabricating some kind of log splitter. I think "peakbagger" said he used autocad in the past. I have an associates degree in mechanical engineering and blueprint reading and also have autocad 2000 certification, which is antique by today's standards but still I can dream up some pretty crazy contraptions. My welding skills are not excellent, but i can make two pieces of metal stick together pretty good lol....
I thought about the hydraulic jack option, which is what I grew up using and that is what I want. I'm looking at $1000 or so for a new one big enough to split some knotty hardwoods. 5 or 600 if I make one out of junk and just buy a pump, hoses, engine, and the jack. This is still a little too expensive for me. I too do not like the "gearbox or speed-reducer" method as I first mentioned, but thought I may be able to find one of those gearboxes somewhere, and use some sort of engine from a lawnmower or cheep chinese atv engine to power it.
I have also thought about a type that I have not seen before, but thought of myself. I was thinking that if i could find a way to make a high speed winch, and a tall structure to build from, I could hoist a heavy weight, (300 lbs or so) up in the air about 12ft, then suddenly drop it onto the round to split it. I haven't give this much thought tho.
I have looked at the kinetic splitter and love how fast it splits rounds, but my concern there is that I think the gear and the rack would wear out pretty quickly due to the high rate of acceleration when you pull the lever. Just looks like it would be breaking or wearing out pretty fast.
Back to the hydraulic options, I thought I may be able to save some $$ by using a power steering pump from a vehicle, but soon learned that that style pump is the vane type, and don't really have enough pressure to push a ram, unless you use a huge ram and then the speed would be like 1ft per min. WAY TOO SLOW AND WEAK.
So far I don't see a way that I could find or buy a heavy duty gearbox, I'm not gonna shell out $1000 for a new store bought splitter either. My "lifting a heavy weight high in the air and letting it drop".. well thats pretty much a pipedream. Not gonna happen in my opinion.
If you wanted to build a splitter, had a welder and some scrap metal but no ram or hydraulic cylinder or pump, but had like $100 to spend, what could you dream up? I have looked at those cheap splitters that uses a normal jack with two leavers to basically "pump" the round into the wedge, but that looks just as hard of work as swinging the maul.
Im going to keep my brain working and looking for options. I do have a 10 yr old that loves to watch trees fall, and he loves to show how strong he is by chopping wood. I personally seen him tire himself out trying to bust a piece of knotty beech that I gave up on 3 months ago and its still as tough if not tougher now, and after about 2 hours and 15 breaks for rest, he finally gave out and went to playing xbox. (Wish i had it that easy)... but anyway safety is a major concern. If I had the gearbox version I would have to lock it up and guard it 24/7 as with any dangerous tools or any splitter i rig up. Even with a hydraulic ram type I know they not 100% safe as I have seen quite a few jump off the wedge and go flying, but much safer than the "soon to lose a hand or arm" versions. I don't know... ill keep swinging till I find the right piece of junk to build with.
Side note: Have you guys seen the videos of the splitter that uses a big circular drum with a axe head welded onto it?... it spins around so fast that you don't even have time to stick a piece of wood under it before it comes down again? One small slip and off goes your hand or arm,, and if you lean over too far your dead?...... don't even recommend that type... def not gonna happen at my house... id rather freeze.
Love all you wood hoarders!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
