Hi folks,
I bought a 1967 ranch house last year with an original masonry fireplace. The sellers had the flue relined with a stainless steel liner that looks to be about 12" diameter. The liner is (now) clean and in perfect condition. The firebox had a golfball-size hole in one of the front corners that I've patched and still has hairline cracks in the mortar that could be fixed with caulk-tube refractory cement.
I'm confident I can take care of the easy stuff, but the smoke chamber that I'm not sure about. The back corners of the smoke chamber have 1/4" wide vertical cracks where the two sides meet, running most of the way up. There are some defects in the parging near the top and other hairline cracks here and there.
One chimney technician said it was fine to use right away--before I found the golf-ball sized hole he missed. A second company offered to patch the cracks by stuffing refractory mortar in there with a tool on a pole. Of course, there are other defects visible (such as bare cinderblock at the very top), and I'm not confident that a simple patch of those cracks would be a permanent repair. Somehow the material shrank enough to open up those cracks in the first place.
At least one local company offers the Smoktite system, which looks like a good concept if it adheres properly to the underlying material. If it works I still have the original masonry fireplace to use, but the durability would also depend on the care and skill of the installer. The cost would be about $900. Does repairing the original masonry fireplace improve the home's value more than an insert?
Complicating the situation is the fact that the plywood molds under the hearth were never removed. Removing it would require knocking out cinderblocks in the crawlspace to access--not a pleasant proposition. I discovered plywood pieces sticking across the hole--the home inspector didn't bother checking this, of course. I then cemented a cinderblock piece into the bottom of the hole as a plug and filled the ash dump chute with 12" of poured concrete. Altogether there is probably 28" of masonry--firebricks on top of regular bricks on top of two levels of cinderblock on top of 12" of concrete which is then on top of the plywood. I would think the risk of conducting enough heat to start a fire down through all that concrete and concrete block is pretty slim.
Is the Smok-tite system really a permanent repair? In general, is it more beneficial to home value to maintain the original masonry system versus switching to an insert? The heat efficiency of an insert is somewhat appealing. It, too, would draw combustion air from the surrounding space, necessitating an open window, correct?
I did some preliminary search of the forum archives before posting and didn't come up with as much as I'd like, but I'd appreciate a nudge toward existing threads if this has been discussed many times before. Thank you!
![[Hearth.com] Can (or should) this smoke chamber be salvaged? [Hearth.com] Can (or should) this smoke chamber be salvaged?](https://www.hearth.com/talk/data/attachments/220/220312-7418869109f932186f896b14a5ff9f82.jpg?hash=NkypbXrudJ)
