I'm renovating a small bathroom and want to drop the floor down a few inches so the tile is flush with the hardwood flooring in the hallway. This will require removing 2" or so from the top of the floor joists. Joists are 2x8 16" o.c. spanning 11'. I could sister 2x6s along side the cut joists but according to the span tables I've checked, 2x6's alone won't cut it and it's not real clear how to calculate the contribution of the cut joists to the overall structure. FYI this is a ranch so only one floor to worry about, and full access to crawlspace below (and attic above.)
Pic of basement, bathroom area back left where all the plumbing is. Looks like piers under the main beam are sitting right on the slab, but maybe there are footings under them?
Can I build a small knee wall in the crawlspace to reduce the span in half? Then maybe sister 2x6s on the cut part for good measure? Would I need to cut the slab and make footings, or can I just tapcon a pressure treated 2x4 to the slab and frame up the knee wall?
![Can I frame a small knee wall on a concrete slab to reinforce floor joists? Can I frame a small knee wall on a concrete slab to reinforce floor joists?](https://www.hearth.com/talk/data/attachments/178/178956-fbf79fc2097b9a0d9edd46acab11b37e.jpg)
