jtp10181 said:FYI here in Wisconsin we sell a LOT of 7100-FP and Northstar units which are EPA built in fireplaces that use air cooled chimney (HHT SL300). They can take the "DuraPlus" insulation packed venting but we only use it if a customer asks for it. We don't really have any problems caused by the air cooled chimney.
rjustice4 said:Sean, what would be the disadvantage of leaving the insulation the way it is, and just going with the Exhauto approach? That way I don't need to tear the chase apart, and I know I have draft when I need it (just flip the swith on the Exhausto). Sees like a sure bet.....
rjustice4 said:Thanks Sean, sounds like I really need to get a look inside the chase and see if it is insulated...
One thing I haven't been able to figure out is where combustion air comes from in these fireplace designs, is there some kind of vent that's not illustrated in their drawings....? I see cooling inlet and outlets, blower intlet and outlet, and chimney outlet....but no combustion air inlet. Do you have any idea where the combustion air comes from?
rjustice4 said:Thanks for the input, BTB.
Your right in pointing out "best practice" installation as of 2007. My stove was installed in 1993 when the Xtrordinair was in its infancy (had just been aquired by Travis, as I understand it), and I bet the current installation guidlines have evolved over the years. Now I'm stuck with trying to upgrade the installation (by spending a lot of money to tear things apart), and/or using an external fan (such as the Exhausto) to remedy the flawed installation.
Good idea on the drill, I was thinking the same thing...whenever I pull a drill out of an insulated wall, along comes some insulation.
I'd also like to get an exploded assembly diagram of my model, and inspect all the parts, including the catalytic unit. In what I have left from the manual, it says you need to contact Corning for replacements...I guess it's some kind of glass....
I'll take a look at the thread. I hadn't searched FPX, only Extrordinair....
elkimmeg said:You know a clogged combustor will back up smoke and cause excessive smoke in the chamber so that everytime the door is open it will puff out
