I bought 2 full kits. Just made sense money wise since you get an extra head that way. Used all but 1 rod, 11 total. I found using a small nail punch made it easier to depress the release button.
Did the same here.
Also, here is a tip if you purchase. When it comes time to trim the "weedwacker" part to fit your pipe, loosen up the nut and just pull the lead through until you have the right diameter (Cut one side instead of both sides) This should leave you enough extra line as a backup in case you go through the original one.
Also, good Idea on using the nail punch. I have to say the thing I least like about the soot eater is that getting the rods together and apart can be a little difficult....usually the tip of my fingers and thumbs feel it for the next 3 days or so. I wish they made them a bit easier to connect, but they probably make it this was so they don't "disconnect" while you are using it, lolI bought 2 full kits. Just made sense money wise since you get an extra head that way. Used all but 1 rod, 11 total. I found using a small nail punch made it easier to depress the release button.
Did yours (and the others with issues unhooking the sections) not come with the "pointed" allen key? It's provided for pushing in the spring loaded connectors. Maybe it was no longer included in ones sold after mine?
Yep, they have the pointed end....never noticed. I'll remember that next year!I'm concerned about the rotating tip that swirls around. Once it comes out of the liner at the top and swirls around could it hit the cap and cause any damage to the cap itself and/or the cleaning swirls?....
Well look at thatYep, they have the pointed end....never noticed. I'll remember that next year!
Hardly any at all if you put the plastic sheeting (which is included) across the opening to the firebox; you tape the perimeter of plastic all around and poke two holes through one for the rods and one for the vacuum and then almost everything is essentially dustless. It works really well.
Even the included punch isnt perfect. The whole lock system isnt the best design from an installing and removing rod point of view, but it stays locked very well and I guess that's the important part!
When trimming the head, do you guys follow the instructions as to diameter? Ive been thinking that with my new head, I'm going to leave it long to maybe scrub a bit better and last a bit longer.
