Checkthisout said:knock it off.
Do you disagree with this calculation?
If so please explain
Thanks!
Whitsett
kofkorn said:The stove rating of 48K BTU is not the amount of BTU's that the stove puts into the room, it's the total amount that the stove consumes, as BDPVT says "Input Rating". So for a VERY simple calculation, the heat output into the room would be the Input Rating multiplied by the efficiency of the stove:
48000BTU/hr * .78 = 37440 BTU/hr
Since we are calculating this backwards, I am doing a quick sanity check to see if our calculated heat output matches the stated stove rating. Since we are working backwards from the heat output into the room, we divide by the efficiency rating.
Now, I (and I think many other people) don't agree with the way that the EPA comes up with an efficiency rating. It is grossly overstating the capabilities of nearly every stove. As stated previously, the efficiency is a combination of combustion efficiency (~98%), electrical efficiency (~99%), and heat exchanger efficiency (~60%). The EPA takes these numbers and averages them, which really doesn't make sense to me. However, this is a conversation for a whole different thread though.
kofkorn said:As stated previously, the efficiency is a combination of combustion efficiency (~98%), electrical efficiency (~99%), and heat exchanger efficiency (~60%). The EPA takes these numbers and averages them, which really doesn't make sense to me. However, this is a conversation for a whole different thread though.
whitsett2014 said:
kofkorn said:Now, I (and I think many other people) don't agree with the way that the EPA comes up with an efficiency rating. It is grossly overstating the capabilities of nearly every stove. As stated previously, the efficiency is a combination of combustion efficiency (~98%), electrical efficiency (~99%), and heat exchanger efficiency (~60%). The EPA takes these numbers and averages them, which really doesn't make sense to me. However, this is a conversation for a whole different thread though.
whitsett2014 said:So,
I We concluded that because we are measuring output temperatures directly, that the overall efficiency does not need to be taken into account. (feel free to comment if you disagree)
tjnamtiw said:If you are a renewable energy consuming company (or hope to be), why would you not want to consider how much energy you are consuming in order to get a given amount of output? That is efficiency. Even your renewable energy takes energy to manufacture. That's why your pellets aren't free. It's like the very plausible argument against using corn to produce ethanol for cars. If you are consuming more energy to make your fuel than you are getting out of it, then it is no longer viable.
whitsett2014 said:Sum all of these and convert to BTU/hr comes out to 305.65
whitsett2014 said:Infrared temperature gun says otherwise
nothing notable as far as surface temperature change is concerned about the top, back, or sides. Less than 15 degrees C, most cases less than 10.
whitsett2014 said:I'm still unsure of what surface you are referring to. I am only measuring surfaces which are in direct contact with the ambient air. All other surfaces are being neglected on account of I cant get to them without taking it apart... which sounds like a lot of work for a couple hundred BTU/hr.![]()
