St_Earl
i have had one jam at the top end of the auger in nearly four full seasons.
i poked a wire up the drop chute from inside the firebox and that cleared it.
heatilators have an "open" style auger and are very jam resistant.
the bottom end tapers to a point and the auger "floats' a little in the channel.
yep, ash is a whole different and delightful topic.
i prefer light (in weight) fly ash because our stoves are designed to blow the ash out of the burn pot and into the firebox.
the crabbe pellets i still have make a kind of ash plug as they make a heavier ash than my mwp blends. it's not a clinker, but it's not what i really want happening.
right now i am mixing the two until the crabbe are gone.
i much prefer dealing with fly ash than having to use the pull rod a couple times a night.
with just straight mwp blend, the firepot basically never gets dirty and blocked up.
and the ash drawer takes ages to fill up.
i am fine with removing the fly ash a few times a week in between cleanings.
i just scoop it out with a flat piece of sheet metal i have and dump into a metal bucket.
i can do this while i still have coals in the pot, shut the door and resume burning without having to restart the stove.
i do have a pair of leather work gloves dedicated for stove work. it's too hot to do that procedure barehanded.
. Your stove is in such a cold environment this could be your problem. What I've done to remedy this is before firing up take a hand full of pellets drop them in the pot then fire up. Although my basement temp never reaches what you have there this could help you get going even if you still have to hit the reset a couple of times.
