Buying wood by the semi load
Como
885
Colorado
www.comodepot.net
I need to get some bids for getting my wood in for next year, so I thought of sending this out:
Log length wood required for delivery by September 1 2011
Multiple tuck loads producing a minimum of 55 cords.
Specify wood type, and average diameter.
Delivery location ......
Terms - COD
Am I missing something?
Terms - COD
Couple of items "hit" me:
If this is for next year, you want to start delivery yesterday, and specify rate of delivery as appropriate.
What is "log-length"? "Run of the woods" logs encourages logger to sell you some air. Maybe spec max & min diam.
You want to specify species/mix, as possible, knowing lower BTU/ton of conifers. Say "no" to poplar?
You might want to provide information up front as to stuff like axle-load limits, max. grade & truck height.
COD per load?
For what you're talking, you should be able to interest logging co. in sending an agent to you to discuss options.
Meanwhile, you might also send requests for proposals to local tree services to drop off "woody waste."
Terms - COD
55 cords will last me about 12 years. How long will that heat a hotel?
I am in Colorado, a year for seasoning will get me to 15%, I have some wood that is in single digits which dates back 2 1/2 years.
My calculations are that I will need 50 Cords, 10% for safety. Around here log lengths are 40ft, I will add that as a question.
The building is not that big, I am sure there are people on here with Houses bigger. We do have high ceilings.
I was thinking it would be 4 semi loads.
So now I'm really curious about the size. How big is "not that big?" How many stoves do you have?
5,500sq ft ish
I have 2 stoves, but am likely to us only the Hearthstone Phoenix, the other one is very inefficient and will pump too much air up the chimney.
Hopefully they are conservative, the big variable is solar gain, no way of computing that - but then we have the wind.... as well.
I have my calcs, Professional Manual J and local experience in sort of comparable buildings.
However as Napoleon said No plan of battle ever survives contact with the enemy.
Have you ever tried heating it with anything other than wood for fuel, and if so, how much did you use?
Are your high ceilings a cathedral style, or central open plan with rooms stacked in the periphery? How high are they?
Nosy parker minds want to know . . .
Terms - COD
How many cords are you going through in a year?
Terms - COD
COD per load?
Colorado is dryer than a popcorn fart and full of pine. It'll dry just fine over the summer.
Hurricane, that was to be my question also.
David, 55 cord is a lot of wood even for 5,500 sq. ft of house and especially for only one stove. So that leads me to think you are talking about face cords rather than full cords. I'm sure you know thought that a full cord of wood is 128 cu. ft. Or a stack 4' x 4' x 8'.
It is good that you already have next winter's wood put up and will not need this next year. Otherwise it might be tough to get it dry enough for next winter. I've never thought that most of Colorado is all that dry of a climate but for sure the wind will be a blessing for drying the wood. We wish you good luck and hopefully you'll get more than one bid.
Don't know if anybody else has looked at his blog. It hasn't been updated in almost a year, but the plan was for two big GARNs. That means a pretty big heat load.
How can one stove burn 55 cords of wood? The phoenix isn't as big as the equinox and unless he is burning with the air open how do you average a cord for every week of the year? If he was running 3-4 stoves maybe, but one stove 50 cords in a winter? LOL
55 Cords? Just putting that in the stove is going to be a full time job for two men and a boy.
Are you sure you're going to burn that much in a year? Or maybe you're getting 10 years out on your wood supply?
If you're really going to burn that much I salute you sir!
I do have 2 stoves, most of the wood will be going in the Garn's.
One of the stoves sit in what was a fire pit. Had a guy round last year who was a friend of the son of the people who owned it at the time, they burnt 70 cords in that fire pit in 1979!
I currently burn about 6 cords a year, but the building has been shut down in the winter, that was April to October.
Must update the blog, thanks for the reminder.
The old stove in what was the fire pit.
The fire pit is a new addition, 1952.
I think the stove was put in about 30 years ago.
Nope
Wood something, I will look tomorrow, dark and snowing!
It will take most of a wheelbarrow, I usually put in 3 or 4 large splits at a time.
I load it up last thing to cut down on the Propane, it is cold by the morning, the Phoenix will usually have hot coals to keep going.
I gotta get down there one day. Do you think it's worth modifying to secondary air? Longer and cleaner burns.
The Stoves, no. If you see the size of that chimney it sucks a lot of air out which is why I do not intend using it once the Boilers are on line. The kitchen exhaust is a much bigger issue. So that will be the first thing to be addressed.
