I'm not positive but I think my stove is steel, not cast iron.
Is there any way to properly test a combustion blower? I don't mind spending the money if I was sure it would correct the problem.
You'll have to get an airflow meter to do a definitive test otherwise you have to go by how it sounds and how fast it ramps up to full speed when hot wired and the current draw when it gets to speed.
If you didn't get the termination cap clean you'll have build up issues the same as any other part(s) of the stove that has ash stuck in it.
I think 22' at 3" may be your problem. My manual recommends 4" for any runs longer then 15'. ?your stove may be different, but that may be an item to consider.
Interesting....so there's no turn from the rear exhaust to go up the chimney? I don't remember a top exhaust vent on this stove.My vent run is only verticle, I have no horizontal or T elbows so my EVL is only 11 or 12 feet.
A friend just had this same issue(P22 freestanding) with burnpot building up in less than 12 hrs. Plus a lazy looking flame. I stopped over last night and ran the brush up the venting for him. Unfortunately that wasn't the issue. Stove still had no draw and a lazy flame. He was cleaning behind the 2 doors, But somehow ash was built up above that area. I used a soft faced hammer and wacked the inner back wall and it all fell down towards the clean out doors. She's purring now!![]()
Is the damper Wide open? Or are you still trying to run with it at your normal position.
Your EVl is likely 16' which is still fine IMO. Especially because this ISN'T a new install and the stove did work properly before this issue.
I would check cap (its gotta be crudded up) thump the back wall, and add some oil (3-n-1 Blue bottle/ SAE 20) to the combustion blower bearings (even if there sealed bearings, it will help).
Anyway to get on the roof?
Why not try damper wide Open? Shut down, clean pot, open damper, restart with it 100% open on setting 2.
How far closed is your damper now? (Like right now as pot was filling)?
Pellets, like any combustible, need air to burn. The more air, the more complete the combustion and the.more fly ash gets ejected from the pot (keeping the pellet pile down and ash out)
What Eric was talking about with regards to behind the clean out panels was open areas on the back side of the burn box wall and suggested
Pounding on the wall to remove build up. I use a noodle brush that you can get at HD and bend to go on through those panels and clean up the back side and also towards the other panel. A lot of times material gets caked back there.
Especially an old and dry one![]()
