I don't think he is sick because of food allergies because he is still on the boob, though other allergies may be the cause. He recently started to go to daycare, where they have a cat, and spring time trees budding out may also be a factor.
Welcome to the forum Craby. What a name! One thing not mentioned so far is the wood. My question would be are you keeping wood inside the house? Or are you just bringing in enough at a time to load the stove? That could make a difference. In addition, you mentioned shutting off the humidifier and that is good. There are still a few other things you can do. First, before opening the door, turn the draft to full open and then wait a few minutes. Not seconds, but minutes. Then open the firebox door slowly at first (that first couple inches) then once past that just get it open and put the wood in. Do you have a ceiling fan? That too could be shut off. And while we are on this, make sure that fan is sucking air up rather than blowing the air down . Are you running a clothes drier? Exhaust fans by cooking stove and in bathrooms? Those are air robbers and would tend to want to draw air from the stove as you open the door. I hope these things work well for you and that baby gets healthy once again.
Thank you for the welcome. I've learned allot here.
- I was storing a couple weeks worth of wood by the stove. The new stove uses very little wood & I was used to keeping alot around because I had a Buck 91 that had a larger firebox. I have shut down the stove for the past few days & removed much of the wood especially now that the shoulder season doesn't require as much.
- I need to be not soo hasty in my reloading. Thanks for the reload breakdown.
- I do not have a ceiling fan.
- I have not noticed the clothes dryer & bathroom fans causing a draw on the stove. Probably should do a test by reloading as you described with one or both exhaust fans running to see if it draws smoke.
For relief, bring him into the bathroom with the shower running for a steam bath.
The pediatrician recommended this steam bath. Just skipped our mind so I'll need to try it out.
another place for mold is behind wallpaper
No wallpaper in the house, though it did not occur to me that it is a vapor barrier. Good point.
Where are you measuring humidity? Humidity ideally needs to be measured away from the stove and away from the humidifier. If bedrooms are cooler, the humidity would be higher. 50% winter humidity is borderline too high for a not highly insulated house as the space in the walls will potential be significantly higher humidity than the rooms on cold days. Adhere to cleaning/maintenance schedule on humidifier. You can try running your circulating fan on the furnace to clean the air if you have a nice filter in there. Make sure you do not have a humidifier active on your furnace when using wood.
- I'm measuring humidity in our baby's room. The humidifier is in the stove room.
Bedrooms are cooler, so I'll drop the humidity to around 40* & see if that helps.
- Good point about the humidity levels being higher inside the walls. The exterior walls are brick veneer on CMU block, with drywall on 1" furring strips mounting to the CMU block with no insulation. Overall 12" thick walls. I have R39 in the attic.
- I purchased the humidifier (Honeywell QuiteCare HCM-6012i) in the past few months off Craigslist already used but with a washable air filter, & started using it immediately not thinking to clean it. I bought some antibacterial & humidifier cleaner & gave it a good washing this past weekend.
- I do run the furnace recirculating fan 24/7, 365 days a year & have an electrostatic air filter in there. I also have an air ionizer mounted inside the supply duct.
- I did not know it is bad to have an active humidifier on the furnace when using wood. I had and Aprilaire 700 running till I bought the Honeywell humidifier. I turned off the Aprilaire furnace mounted humidifier about the same time he came down with croup. I turned it off because I just heard the sump pump on the furnace cycling allot and humidity was low at around 15-20%. I figured it was because the furnace was not calling for heat & so the water on the humidifier pad was not evaporating. Do I need to wash the Aprilaire as well or just leave it turned off?
I'm going to run the Whirlpool hepa air cleaner by my wife, so thanks for the link.
