So I just got a killer deal on some green wood. It's slab wood from a lumber mill. He said it was green AFTER delivery but I decided to hell with it. I'll give it a try since my chimney was cleaned 2 months ago and I have been burning seasoned wood up until now.
So I grab about six 1"x1" pieces mixed with some offcut 2x4 I had. into my fire. It started with a brief period of smoke and I thought yeah this won't work.... but then it proceeded to burn hot at nearly 300° Celsius.
So I placed some wood in front of the wood stoves blower but far enough that it doesn't pose a hazard. It's an insert with a blower, so they were at blower height.
So once the fire died down to around 200° celcius I threw the 2x2 green stuff in the fire and after a slow start it fired back up to 250°c. I repeated this 3 times, it's really really warm inside now.
I know it's bad to burn green wood but if I'm maintaining the high Temps and keeping it above 250 is creosote still a big concern? I can start the fire with dry kindling and maintain Temps with the thin green wood as long as there is no smoke and Temps are high? I'm looking for some clarification and guidance here since I've never burned green wood before.
On a side note I am only burning thin pieces, maxing put at 3" thickness. I currently have two small piles sitting on my central heat vents to assist drying over night when the heater is running and I plan to make a nice little storage bin that sits Overtop the air vent so i can place a bunch of 2x2 3x3 pieces in there to dry whenever central heat is running. And I'm cycling these kindling sized pieces I'm making to sit in front of the blower a safe distance away.
Thanks
Thanks
I also had one cranky old green Poulan saw. Hand split everything. Filled my stacks fine.![[Hearth.com] Burning green wood [Hearth.com] Burning green wood](https://www.hearth.com/talk/data/attachments/289/289591-42a25fb98f6e549ae4ca2fa420e1a519.jpg?hash=T1Vk8SUZyh)
![[Hearth.com] Burning green wood [Hearth.com] Burning green wood](https://www.hearth.com/talk/data/attachments/289/289607-68e3525c56119ca3d503ee8ba7a505b2.jpg?hash=lp429_1DLv)
![[Hearth.com] Burning green wood [Hearth.com] Burning green wood](https://www.hearth.com/talk/data/attachments/289/289609-d2e91b4e45ba047c395067f27f4f07b0.jpg?hash=hfSH3l8Cdk)
![[Hearth.com] Burning green wood [Hearth.com] Burning green wood](https://www.hearth.com/talk/data/attachments/290/290129-9737c4d74774c477009c5022989762ca.jpg?hash=DQPU1Ung2T)
![[Hearth.com] Burning green wood [Hearth.com] Burning green wood](https://www.hearth.com/talk/data/attachments/290/290135-81ec38fed89ead4441eebec688d286b7.jpg?hash=TbeObqJyQd)
