Burn times
wow, I need to get this kind of burn time...right now I'm checking/ adding every 2-3 hrs 24/7
Is this because of a small firebox, or the way the firebox has to be loaded? Our Jotul F400 was every 4-8 hr depending on the heat demand, the T6 is every 8-12 hrs again depending on how hard it's being pushed for heat. Sometimes the universe comes together and I get a 14 hr burn.
Reactions: ctreitzell
it's because the flue cools too quickly if the air intake is too closed down
I was overloading the firebox last year to get 4+ hr burns; I was packing it full...
the baffle is melted to a 1/2 pipe...just about ready to slip out of its bracket
The Panaderos are not cast
I know choked embers will last for many hours with no airflow through the Panadero...I could start heating the flue before opening the air intake...but I run the risk of a smoky morning...and cool rooms will occur
at some point I'll start looking for a better solution...this year, tho, I expect to be stuck with this Délice...unless it becomes very dangerous...I believe the weld on the bottom of the exterior body has leaked creosote...so if forced to send the stove back to Panadero, I'll need to know what to replace it with...and I'm certain no other stove will connect directly to my chimney...other than another Délice/ Dover...ugh, so we could buy a second one
funds are tight!
