What is everyone getting ? That includes how long is your flames and how long does your coals stay hot for ?
Damn, that’s a good burn time, are you burning oak ?In the dead of winter, with my Jotul 550 insert in a full load of good hardwoods, I get probably 7 to 8 hours of usable heat. After that point, I’ve got some warm coals to reload on.
With my regency 2450 freestanding stove, I get probably another hour or so more maybe. Both stoves are 2.1 ft.³ I believe.
I should specify I’m only seeing flames for a small portion of that 7-8 hrs.Damn, that’s a good burn time, are you burning oak ?
Okay, so at what temperature do you usually reload your stove ? I usually do mine at 300 or when the coals are down. Right now I’m burning soft maple. And thank you for telling me now. I thought you was getting flames that whole time.I should specify I’m only seeing flames for a small portion of that 7-8 hrs.
At that 8 hour mark my stove top temp of about 200 degrees.
This would be with burning either oak, hickory, black birch, etc. I wouldn’t get those times with soft maple for instance.
What kinda wood are you burning ? I got 8 hours yesterday ?I very rarely actually load my stove very full. I use 3 or 4 mediumish sized logs then turn it down once its going well. Heat lasts around 8 hours. Flames only about 45 minutes. Then just occasional busts of pretty lazy flames.
So you usually stack the wood in your stove ?The longest burn I've gotten was like 15 hours. It was an overnight burn with a mix of oak and hickory. The box was packed tight. Normally I dont fill the box completely during the day. I like to let the house cool some. with the box 3/4s full I'd say probably at least 8 hours
I have been nervous to load the box before bed. Still getting used to the stove, only a week in. I like it so far. Big adjustment to automatic damper. I used the outside air kit as I live in a very tightly wrapped double wide modular.The longest burn I've gotten was like 15 hours. It was an overnight burn with a mix of oak and hickory. The box was packed tight. Normally I dont fill the box completely during the day. I like to let the house cool some. with the box 3/4s full I'd say probably at least 8 hours
Be patient, give yourself time to get comfortable. What stove is this?I have been nervous to load the box before bed. Still getting used to the stove, only a week in. I like it so far. Big adjustment to automatic damper. I used the outside air kit as I live in a very tightly wrapped double wide modular.
ASPEN C3 - purchased in the summer, installed a week agoBe patient, give yourself time to get comfortable. What stove is this?
What do you mean by loading it up? Depending on how you split your wood, you may only be able to fit three splits in there. If you are splitting at 3”-4”, you can pile it in decently.ASPEN C3 - purchased in the summer, installed a week ago
wow, I need to get this kind of burn time...right now I'm checking/ adding every 2-3 hrs 24/7I very rarely actually load my stove very full. I use 3 or 4 mediumish sized logs then turn it down once its going well. Heat lasts around 8 hours. Flames only about 45 minutes. Then just occasional busts of pretty lazy flames.
