That's the problem; Your wood is too good. You need to stock up on Tulip Poplar.The stove might be just a tiny bit too big for my home and geographic location; if I give it room to breathe it will melt the house....80% with white oak and hickory.
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
Great thread. So how are stove top temps being derived? FLIR? IR Gun? Magnetic thermometer?
These can be vastly different in accuracy.
Where are readings taken? By the flue collar? Over the cat (if equipped)? Near fan air exit or near the front? These can be vastly different one stove to the next.
Are the blowers on or off during the taking of temp readings?
If any credible comparisons are to be made (and there will be), set up a plan so those providing data provide a more apples to apples comparison.
Just my .02
BKVP
I typically reload around 250 to 300 on the stove top. It usually cruises between 600 and 700
I heat from the basement like I said before so yeah it is pretty warm down there but comfortable upstairs and I like doing it that way because it really tempers the temp swings of a non cat stove. Plus it keeps the mess out of the living area.600-700 man your room must be like being in the caribean. My stove is in my man cave downstairs and i Dont let it go above 450-500 too long cause the room will start going above 83 when im in it. Just was watching the show on netflix THE OA pretty weird but even better when your near wood heat and relaxing.
We have two stoves. Regarding the main stove, from the stove's manual available at:
https://www.lanordica-extraflame.com/en/products/wood-stoves/rossella-plus-forno-evo
"Firebox size" : 37.4cm x 37cm x 35cm
"Burn times" : The stove will burn 2.4 KG of wood an hour at nominal output. For max load, do the math (wood weight for available volume) to see how much wood can be added to the above burn box space.
"Stove temps" : This is a convection stove. Wrapped with a tile layer. External temps of the tile is hot to the touch only and internal firebox temps are not directly measured. This stove has a cooking oven, and that oven does show temps: usually between 200°C-300°C
"How often to you reload" : Personally, I typically load three logs at a time, every 2 hours or so. That keeps a nice even heat output during the day. Very useful as this stove is also a cooking oven and you can not bake cookies when the oven is 400°C. At night, I let the fire go out. House insulation keeps the house warm over night. New fire each morning.
I'm so jealous
Those cat stoves and their 24 hour burns I've been thinking of a second stove in my basement and I would do a cat stove for sure.
But then again although I have to reload my quad 3100 insert every 6 to 7 hours I'm only burning on weekends when I'm home to feed the stove and run the central during the week. It's natural gas and with the help of my stove part time weekends I'll pay roughly $400 max in natural gas for the entire winter. And it's cold in these parts ( going to be single digits highs and lows of minus 20 all week)
So I'm happy but still jealous of those 24hr burns you cat stove folks get !!
This points out the great variability in stove sizing and perhaps the folly of this question. All our houses are different. Sometimes the difference is so great that a big stove is barely adequate in one and loafing in another. Houses vary in so many ways (insulation, construction material, ceiling height, age, room sizes, stove location, number and size of windows, floorplan, number of stories, stairwell location, etc.) and geographic locations and climate zones that the results are only relevant for near identical situations.600-700 man your room must be like being in the caribean. My stove is in my man cave downstairs and i Dont let it go above 450-500 too long cause the room will start going above 83 when im in it. Just was watching the show on netflix THE OA pretty weird but even better when your near wood heat and relaxing.
Princes PI 1010 INSERT Stove top temp measured far left side IR gun 425 Magnetic 400 degree blower on med setting one hour into the burn Pine and red oak full loaded N/S.Cat temp pointing to 4 oclock most of the time.T-stat set to 3-4.I use the fan speed to control the top of stove temp like the manual says to do. I have been burning apox 8 weeks only problem now is my vacu-stack drafts (no problem with 10-30 mph) more than it should on windy days with 40-60mph winds. These excess winds will change my t-stat setting to almost full closed with the cat temp pointing to 4 oclock and climbing top of stove stays about same temp. This forces me to select high setting from the fan to control the high cat temps which affects my burn time.Great thread. So how are stove top temps being derived? FLIR? IR Gun? Magnetic thermometer?
Just my .02
BKVP
A week of -20 would have me buying an IR camera and plugging leaks in the house, too.
Replacement double pane vinyl windows are cheap, easy to install, and make an unbelievable difference vs 1970s windows.It's funny how when it's that cold out you can feel cold air from every leak. I've plugged lots of leaks. In my case my insulation is whatever was typical in the 1970s combined with old windows and one door that still is original and well a not so tight house.
Thankfully my central is newer and very efficient.
If I could do it over again I would have started with a large 4.0 cubic foot stove in my basement flue. I've got central heating duck work above where my stove would go. Cut a few registers in the ducks and should get some good heat upstairs. Then instead of my wood insert I would have put a gas insert in my fireplace instead. Leave all the wood and dirt in the basement.
oh I insulated allot our first year here we went through 8 tanks of oil. The last year I heated with only oil I had it down to 5. But I have insulated more since thenI guess it's a lot easier and cheaper to burn wood then it is to insulate ones house. I know this because I wrote a thread a lil bit ago about buying a second stove or to insulate. Many pointed me to insulate.
use bubbled wrap and a spray bottle of waterIf it got down to the teens. I would need to put blankets on the windows.
The answer to your question of "burn time" has many facets and is based upon:
- Desired inside temperature
- House size
- Level of insulation in the house
- Outside temperature
- Woodstove efficiency percentage rating (equates to the amount of heat not going "up the chimney"
- BTU's per hour
- Combustion chamber size (amount of wood the stove will hold)
- Wood type being burned
- Wood moisture content
- Draft
With that being said, I'm sure there is a mathematical formula to solve this problem but it will take a greater mathematician than I to develop it.
Here are my answers to the above points as it relates to my house and the Progress Hybrid.
With the above considerations, I can get between 10 to 12 hours of "burn time" maintaining a stove temp above 350 degrees and can maintain an average temperature of 70 degrees inside the house. Also, I consider "burn time" from the start of a fire to a minimal level of coals in the stove in which I can restart the fire.
- Desired inside temperature: 70 degrees
- House size: 2,400 sq. ft.
- Level of insulation: Normal (not really tight)
- Outside temperature: 30 degrees Fahrenheit
- Woodstove efficiency rating: 81%
- BTU's per hour: 73,171
- Combustion chamber size: 2.8 cubit feet
- Wood type burned: Primarily red oak
- Wood moisture content: Under 20%
- Draft: Normal
Definitely not "scientific" enough to really answer your question but that's my "two-cents" worth....
This is with new double pane windows all around. Unfortunately even good windows don't provide much R value.
If our old farmhouse had any more glass it would be a greenhouse. It got a remodel by city folk in 1984 and they added a lot of windows, (then moved out a year later). It's nice most of the year but when it gets cold out you know it and I have to push the stove to keep up with the heat loss. This is with new double pane windows all around. Unfortunately even good windows don't provide much R value.
I know I could save a lot if I did it myself but I'm not the best carpenter in the world ( ok I suck at carpentry) and the windows are all custom sizes. On top of that casement crank windows are what would look best on the house so that's even more money.
This stuff was easy to install and is doing the job for me. You install it on the door jamb with the door closed, so that the vinyl bulb is touching the door. Don't press the bulb against the door too hard, or the door will be hard to close. Tension is adjustable, though.1 very leaky old door. The door I can get done for reasonable price. I should do the door.
