Why is my burn pot overflowing with unburned pellets? I have been using Greene Team pellets this season and I can't fire my stove above heat setting 3 overnight without unburned pellets flowing over. I called Englander and explained my problem. I was instructed by the rep to install a new burn pot gasket as it is a 2003 model and it may be worn out. The gasket arrived, a meticulous cleaning performed AGAIN on every part of stove (I took my time and removed EVERY part and cleaned them and did leaf blower trick) and it is still burning horribly. I find that even during the evening when I am home, if I fire the stove up to 6 the glass is dirty within 4 hours or so and the pot is close to overflow. I have replaced the door gasket, window gasket, hopper gasket and it is still not performing like it use to. Maybe the combustion blower is weak? OAK is installed and nothing is blocked. Any suggestions or insight would be appreciated.
