Burn pot full of ash in my 55-TRPEP
Well I am on my third day and I am a much happier camper. I was able to run my stove for 3 day without a cleaning and it was still functioning very well. I still have a little ash in the bottom of my burn pot. I think its due to the leaking around the burn pot(I took the gasket material out so I could test just the control board change). I am going to put the gasket material around the burn pot and try again. But at the very least my main issue seem solved. I think once I get the burn pot married to the cradle better I will be 100%.
Now what do I do with all my spare time, maybe it time for cooking a little home brew. Does someone make a pellet brew pot burner? Why wouldn't beer taste better cooked on wood like steaks
Thanks again for all of your help and Merry Christmas.
Reactions: SmokeyTheBear
Eric, what mode setting did he have you put it on? I am having identical issues.
It was a 3 and now I am set to a 2. I was told the controller defaults to 3 if its reset. To check this unplug and re-plug in the unit. Quickly press the up and down arrows (at the same time)for the blower it will then display a number using the heat range arrows adjust the number to your desired settings. Hope this helps.
