building my own hearth pad--question about using marble
krondalou
22
Grass Lake, MI
I have 1" thick marble slabs 9.5" wide and 48" long---My hearth pad is cut to 30"x48", and am going to cut the marble accordingly. Question is about what size trowel notches should I use/how thick should my thinset be? And any good reason not to use marble? Also, should I reinforce the subfloor from the crawl space? I put 1/4" cement board on the 1/2" plywood subfloor. My stove is 310 pounds.
  • building my own hearth pad--question about using marble
Reactions: Zack R
What insulation value is required by your stove?
Reactions: Zack R
The hearth construction sounds similar to what is recommended for the Survival Navaho model. Is that what you are following?
I'd start by looking at the stove requirements (in the installation manual) and then working backward from there.
