That's sucks. .. Very unforgiving.We usually start with some kindling, newspaper and a couple of small splits....once the fire gets going, we move up the size of the splits and never fully load the stove...maybe 3 decent splits, nothing too big. I don't sleep well, and usually up every 2 hours to reload, or I just shut the bedroom door and pop on the heat....it has it's own zone. I threw in about 9 shorties in our stove once and 10 minutes later, heard loud BANG BANG BANG....stove temps over 900....I believe I over fired it even though there was no red glow.....now when I open and close the door on the stove, it scrapes the lip, but still seals...barely.
I have heated with wood for about 45 years. As a kid we had a barrel stove we used up in Alaska. Used it in two different houses. It was not a primary heat source, but it was going a lot of the time as supplemental. I have lived in this house since 1986 and have used my stove to generate as much of the heat in the house as possible. I am good at fires, most of this thread has been my surprise to how many people burn their stove. I have always tried to build a fire and keep the heat at a constant size. I see so many people saying that they fill the stove with small wood, let the fire burn hot, burn down, then do it again. I had a thermomiter on my Blaze King, the soapstone hearthstone stove is harder to get a thermostatic reading on. I use an eco fan to tell temp of the surface most of the time.How long have you been burning? Can you send a picture of your setup? Do you have a thermostat on your setup? A lot of your questions can be answered with time and experience.
Yes, for about the last 15 years we have had an Electrathon (electric go carts) team at the local high school.A little off topic, but Electrathon...are you an Electrathon coach?
I put my thermometer on my stove pipe and try to keep it in the optimal zone. Personally I start a majority of my fires with eco bricks. I then put in small kindling on top. When I have a nice bed of coals I put medium size splits and then bigger splits while I'm awake. I watch the temp of the pipe and regulate it to keep it in the optimal zone. At the end of the night I load it with larger splits and turn the intake down where it's cracked open. It will burn all night and in the morning have a nice bed of coals. I'll spread the coals and load up with splits again and open up the intake to warm up the logs until I leave for work. When I get back home I'll have a nice bed of coals again and I'll repeat the process. It works really well. But I can only speak for myself. I have a large vermont castings dutch west stove on one side of the house. When it dips below freezing I'll light the insert on the other side of the house. And the house and everyone in it stays nice and toasty and happy. [emoji2]I have heated with wood for about 45 years. As a kid we had a barrel stove we used up in Alaska. Used it in two different houses. It was not a primary heat source, but it was going a lot of the time as supplemental. I have lived in this house since 1986 and have used my stove to generate as much of the heat in the house as possible. I am good at fires, most of this thread has been my surprise to how many people burn their stove. I have always tried to build a fire and keep the heat at a constant size. I see so many people saying that they fill the stove with small wood, let the fire burn hot, burn down, then do it again. I had a thermomiter on my Blaze King, the soapstone hearthstone stove is harder to get a thermostatic reading on. I use an eco fan to tell temp of the surface most of the time.
My concern over chimney fire issues was not over starting the fire, but in how you keep it going. As far as I remember, every one I have seen (mine or others) was started by the loading of very hot burning stuff in a hot stove/chimney. I agree, if a chimney is spotless, there is nothing there to burn. The reality is that they usually are not spotless. If they were, no one would have ever heard of a chimney fire.About your worry about starting a chimney fire. A chimney fire has little to do with HOW you start a fire, and everything about what you're burning. The objective is to never allow a build up of combustible fuel in your chimney in the first place. .
Can you show a picture?Ill do an IR reading of the stove pipe where it goes into the masonry ,but i doubt if its much over 250 with a 600 stove top.
Not sure where this notion came from but it in general it's a bad idea to fill a stove full of small splits. This could lead to an overtire condition.
My 30 is in a house im rehabbing. I wont be back there until Monday. ID say i have about 5 Plus feet of black metal stovepipe on it before it goes into a masonry chimney.
As you can see I have a little more than that picture in stove pipe and then it goes into masonry. I would recommend getting your temp up over the 250 mark. I don't know how long you have past the masonry til the outside. Do you get a lot of creosote by your outlet?My 30 is in a house im rehabbing. I wont be back there until Monday. ID say i have about 5 Plus feet of black metal stovepipe on it before it goes into a masonry chimney.
How are you getting that big a difference from the stove top to the pipe? How long is your pipe? And what's the temp of the pipe at the highest point? Do you sweep it often? My pipe runs considerably higher but it also runs about the same temp as the top of the stove. Where I measure the pipe is only about a foot and a half from the stove. My pipe at the bend, before it goes into the wall, is around 300 to 350 still. And I only swept it once from last season. I would imagine you would get considerable cool off by the time it reaches the outlet and you get build up.I am coming to this late, but I am a little surprised how many people are talking about continually loading the stove. They just don't work well like that. My advice: buy two cheap magnetic thermometers, put one on the stovepipe, one on the stovetop. They are the most essential things for me for running the stove properly, even more important than my moisture meter. I aim for the stovepipe around 250 and the stovetop around 550. I can take a glance at those two temps (even though I know they aren't exactly accurate) and know exactly what is going on in my stove and what I should do about it. Only takes a month or two of daily heating and you should have your set-up pretty much figured out. Without those two temps your are really just shooting blind.
I only have a 16' chimney, which is on the short side, so I have some challenges with draft at times. I have it swept once per year, no major creosote issues. At startup, the stovepipe temp gets high, maybe 450, while the stove heats up. Once the stovetop gets up to 450 or 500, I start shutting down. The stovepipe temp comes down as the stovetop continues to climb.How are you getting that big a difference from the stove top to the pipe? How long is your pipe? And what's the temp of the pipe at the highest point? Do you sweep it often? My pipe runs considerably higher but it also runs about the same temp as the top of the stove. Where I measure the pipe is only about a foot and a half from the stove. My pipe at the bend, before it goes into the wall, is around 300 to 350 still. And I only swept it once from last season. I would imagine you would get considerable cool off by the time it reaches the outlet and you get build up.
