BTU's on JOTUL vs BK.
After your first 24 hour burn they start to look beautiful!
You know tho...the ashford is more aesthetically pleasing than their other stoves.
I think that the BK is a cat the Jotul is not, if so that's like apples to oranges.
Yes...I realize that...and that's always the ongoing discussion in like groups. To be or not to be...THAT IS THE QUESTION!
To further the comps. JOTUL claims 70,000 BTUs. Blaze King claims 40 some thousand for 8-10 hrs on the princess. That tells me...it will never have the heat output the JOTUL will have?
rdust had this to say in a previous thread...
BK numbers are also average heat output numbers, not the max numbers under ideal conditions. Under ideal conditions they say 90K is achievable.
From page 15 of their manual.
The Facts On BTU’s:
There are only two rating methods that mean something to you the consumer. The first is the Btu output that is achieved
during EPA testing. This testing is quite complicated and costly milled woods are burned. This is a standard for all manufacturer
testing and is not intended to provide consumers with a model for how a stove will burn in their home. The second
method that counts is what Blaze King refers to as the “Real World†method. These btu’s are achieved during in
house testing using the same thing a consumer burns, split, dry, cordwood. In our tests, we use fir. The “Real Worldâ€
btu’s listed are what the average consumer can expect to achieve, with slight variations depending upon geographical
location, type of wood, elevation and the amount of fuel added. Higher btu’s are possible. If you were to stand in front of
your stove and frequently add fuel, burn the unit on high and have optimal conditions, the PEJ1006 could produce as
high as 87,500 btu’s and the KEJ1107 could exceed 90,000 btu’s! However, maximum btu’s would only be achievable at
certain “peak†times during the burn. Blaze King does not wish to mislead you so we give you all the facts.
BTU numbers are not comparable between manufacturers, only useful when comparing stoves within the same manufacturer. IMHO. Voodoo magic.
I'd LOVE to see someone load up five stoves in identical 20x20' rooms and see what the thermometer says on the far side of the room when read each half hour for 24 hrs. Anyone interested?;lol
Reactions: neumsky
The Facts On BTU’s:
That was helpful...thank you!
