So far this year, while burning, I've been very focused on maintaining good stove temps so as to maintain (as much as possible) good secondary burn. It's easy to tell by peaking out at the the chimney. No smoke = good efficient burn, smoke = poor inefficient burn.
I'm getting better at maintaining a good efficient burn. I've started letting my fires burn down to the point, where it doesn't look like there are any coals left in the stove, especially when the temp in the house is comfortable (mid 70s). Last year I didn't stretch the fires out in this way, and instead just added more wood so that I constantly had a fire going. I'm now finding with a good bed of ash in the stove, even after 6-7 hours of no visible fire, the coals can be quickly revived using a bit of kindling and small splits.
I find when I'm not burning efficiently, it's always when I'm trying to turn the fire down, not because too much heat is being put out, but more because I want to get a nice long burn.
My question is this....
From the standpoint of heating the house over a period or time, does it matter how long it takes to burn to go through a complete burn cycle? If so, to what degree?
By this I mean, if a given load of wood is slated to put out X number of BTUs, does it matter whether I spread those BTUs over an 8 hour period, versus putting them out in a 4 hour period? I'm thinking, obviously, the house gets warmer by cranking out more BTUs in a shorter period, but once they're out, it then will take longer for the house to cool to any given temperature.
This question assumes that when running shorter, intenser fires, you are not overheating the room with the insert to a point that it's not comfortable anymore.
Curious what people's thoughts are on this.
