So long story short I just bought a home with a wood furnace in the basement. Due to a lazy home inspector I was unaware that the clay liner in the chimney is cracked and broken until I started to clean and inspect myself. So I now need to install a stainless steel flex liner. My chimney is roughly 11x6 3/4. Based on the instructions on the website the t adaptor that goes on the bottom needs an additional 1/2 inch of clearance. Given that and the fact some tiles are caved in at least 1/4 inch on each side I figure the biggest flex liner I can fit is 5.5 inch. Problem is the inside diameter of the exhaust in my stove is 6.5 inch. So my question is can I reduce the exhaust on the stove to 5.5 inch and use the 5.5 inch liner with no I'll effects? Any expierence with a similar issue would be helpful
