Cool..mines fine but the cam shows wear.Its this at Hechlers
Next season I'll be on my 4th season already so I'll will switch out the door gasket just to be sure.
Is your door gasket glued in..mine is not.
Someone esle said that also on a Princess ..waiting to hear on the full size..you would think it would be.Mine is on the princess
Partly yes, but several areas the glue has let go. Top still holding well & the hinge side.
When I pulled on the bottom it came out & I could see dried white glue spots on the metal.
Every time I fluff it (the gasket), the door latch has more friction & fells like it is closing tight.
Have only adjusted the threaded latch one turn in since new. That was about 2 week after I started burning 24/7, 2 years ago.
To test;
I get a hot fire, then close it down & look for air leaks. I can see cool flames where the door gasket leaks
(the $20 bill test got expensive on a stove thats running most of the time. LOL )
