This is an older stove that's been run 24x7 during late fall to early spring on low. Recently I bumped it from 1 to 2. I woke up to a cold stove. I tried starting her up and it powered on but the auger motor would not turn. I ordered a replacement and found out that it was the high heat circuit and not the motor. Doh! I turned the stove on with the new motor and it started right up. But, it never throttled down from the startup process. As it began to over-fire the fuse blew. Both on the circuit board and the house breaker. I checked my connections and wires and they all seemed fine. I picked up some 5A fuses and replaced it on the circuit board and started over. The same thing happened 3x before I decided to stop from burning down my house.
My first thought is circuit board. My feeling is that when I turned it up something was screwy on it that caused it to overfire. I haven't tried putting my old motor in, in case the new motor was drawing too much power. I also noticed that my blower motor always stays on high. I liked it that way, so ignored it. It kind of feels like its stuck in startup mode too long and then blows the fuse.
Thoughts?
Thoughts?
