I have a Breckwell BIG E and approximately 2 months ago I had to replace the combustion blower. The stove worked fine after that for about a month and then the convection blower went bad. I replaced that too and ever since that the stove does not always work properly. After about ten minutes of running I hear a click and then the auger stops feeding pellets and the stove shuts down. This does not happen every single time and if I press and hold the power button it turns the stove back on and then works fine. When the stove shuts down the number 3 light flashes on the stove. I'm thinking this is the high temp switch tripping but Im not sure if it has something to do with the convection fan or if the switch is bad. It does not happen every time and if i turn stove back on it usually then works with no problems. Any help would be greatly appreciated.
