has anyone burned the boxer 24.any good might take a chance with a cat but a bit nervous if it fails to heat house
.so it,s good for someone in mild climate or well insulated home.No. It's good for much more than that. Because it *can* burn "high". But at that point, you will just have the common 8-10 hr reload (for a BK 30.2 sized firebox; the Boxer will be a bit less).so it,s good for someone in mild climate or well insulated home.
No, it’s a good stove for someone who has a heating need that falls within its output range. That can be a well insulated home in a warm climate or a poorly insulated home in the north. The BK technology excels when the stove is run at lower outputs which means it is smarter to oversize this stove and that’s probably not the boxer model.and i checked my post and i did punctuate sentence,in the right places who knows.so it,s good for someone in mild climate or well insulated home.
He has a large 3.6 cu ft stove. What is needed is better insulation. With the stone walls, a good portion of the heat is going to heating the outdoors.If your house is cold you need a stove with higher output (or insulate your home..) NOT one that can also do a lower output... (With the lower output runs the only times that reload frequency is lower.)
Get a bigger stove...
Your statement suggests you did not understand anything from what I explained...
Okay. That's what I said; bigger stove or insulation.He has a large 3.6 cu ft stove. What is needed is better insulation. With the stone walls, a good portion of the heat is going to heating the outdoors.
