So if it's backing up into there what kind of a problem is there? Just so when I speak to him I know a little of what I am talking about.
I expect it's either a problem with the draft of the main exhaust - which is why I inquired as to how that was setup; or you've got a problem with either a door seal leak or a leak in the internals of the stove between the exhaust and combustion piping.slickplant35 said:So if it's backing up into there what kind of a problem is there? Just so when I speak to him I know a little of what I am talking about.
Yep, straight thru exhaust. Pretty common. I expect you're not getting a good draft. Putting a cleanout Tee and then a vertical section of about 5' of pipe on the outside would probably make it all better. The dealer could even just do a quick temporary install of a section of pipe like that to prove that's the problem. Depending on the prevailing winds, you may be getting wind, etc. coming back into the stove's exhaust and forcing it back thru the stove. The vertical section will stop that. Your manual probably has a comment in it somewhere that the straight thru is acceptable but a straight up option is preferred.slickplant35 said:It's straight out my wall several feet out with a cap facing down. Dont' know if I am explaining it right but that's what it is.
I wanted to test it again last night to see if I still smell an odor but for some reason I had it on auto and it wasn't feeding pellets.
i know that is where the odor was coming from because when my husband was looking behind the stove he saw it was loose and you couldn't put your head behind the stove and when he tightened it you had no odor.
slickplant35 said:..... but for some reason I had it on auto and it wasn't feeding pellets.
You're right. Problem is lots of "professionals" aren't.slickplant35 said:When I tell him that the stove stunk but we tightened it he will probably say okay and be on his way because I don't smell anything. I am confused. I hired a professional not to have problems
The fresh air inlet is meant to Draw air into the stove to provide combustion air for the fire. Like Digger says it should not be PUSHING air or smells out of the stove.slickplant35 said:I have a co detector by the basement door. Should I make him come out and check things out. Now I am very nervous. I don't know a thing about these stoves and if what your saying is that you shouldn't smell anything from the fresh air pipe than something is wrong
macman said:BTW Shane, I was going to go your route w/ the "T" right off the pipe w/ silicone, but it isn't a tight enough fit....would end up using a ton of silicone, plus rope gasket to try to make it work.....that's just not my style ( I help build race cars, and am anal about things fitting correctly...LOL), so will use the appliance adapter.....I'll just feel better about it, it will be a tighter fit, plus if i have to remove the "T", I won't have to deal w/ the silicone....just twist and remove. Besides, it was only $18.
slickplant35 said:So what your saying is even if it was loose I shouldn't have smelled anything? When it was loose and you put your head by the stove to look in the back you would choke. Once tightened you don't smell anything.
Well last night I wanted to start the stove up to make sure and for some reason when I pushed the auto on the thermostat the stove come on but won't feed pellets I read somewhere in the book about heat output but you know what I paid him for the stove I am not going to make myself nuts. Just hope the stove works thats all.
It can be a code violation. My inspector uses the stove manufacturer's installation instructions to decide whether or not to approve an install. My manual says to use an appliance adapter so it would be a violation to go without.Shane said:That's fine, but leading someone to believe lack of an appliance adapter is a code violation is misleading. As for tightness and amount of silicone never had an issue. Guess I did a bunch of crappy subpar installs for almost a decade.![]()
Shane said:macman said:BTW Shane, I was going to go your route w/ the "T" right off the pipe w/ silicone, but it isn't a tight enough fit....would end up using a ton of silicone, plus rope gasket to try to make it work.....that's just not my style ( I help build race cars, and am anal about things fitting correctly...LOL), so will use the appliance adapter.....I'll just feel better about it, it will be a tighter fit, plus if I have to remove the "T", I won't have to deal w/ the silicone....just twist and remove. Besides, it was only $18.
macman said:Shane said:macman said:BTW Shane, I was going to go your route w/ the "T" right off the pipe w/ silicone, but it isn't a tight enough fit....would end up using a ton of silicone, plus rope gasket to try to make it work.....that's just not my style ( I help build race cars, and am anal about things fitting correctly...LOL), so will use the appliance adapter.....I'll just feel better about it, it will be a tighter fit, plus if I have to remove the "T", I won't have to deal w/ the silicone....just twist and remove. Besides, it was only $18.
Shane, just when did I say, or even intimate, that the install was a code violation???? You have me mixed up with someone else. All I said was it wasn't the way to do it for ME!
Shane said:You didn't a guy a couple threads above you did and you agreed that it was a code violation. You are right that if the manual states an adapter is needed an inspector could call you on it......
.....Out of pure curiosity where does it say in the Astoria manual you have to use an appliance adapter? I don't recall that part and most of the install diagrams show either tee's, straight sections of pipe or 45's coming off the stove.
One final thought. In my town the building inspector did not know very much at all about pellet stoves. He wanted to see the manual to verify that what I proposed to do was safe and by the book. He was not ashamed to admit he had not even seen many pellet stoves. I have friends in different towns around me that found the same thing when they went to the building dept. I'm not putting the knock on these folks. They were at least honest enough to admit that. Our inspector was happy to learn a thing or two from me. Point is, in view of this can the inspector be completely trusted, in this case ? I say no, and that's why I became a member here. I've learned much here and spent considerable time doing so. I don't do anything halfa@@ed. The old saying goes " If it's worth doing. It's worth doing it right" In this case wrong can kill you and your family while you soundly sleep . I'm not saying it to alarm you. It's just a fact. Don't cut corners, MAKE sure it's right your ultimately responsible.slickplant35 said:When the inspector was there he showed him what he was going to do and he said it was fine.
