Given the high cost of heating oil I'm considering adding a wood boiler to supplement my oil system. I live in an older house that has average insulation and have been using approx. 1,000 - 1,200 gallons of oil each year for a water boiler that drives approx. 1/3 of the house with radiators and the remaining 2/3 using heat pumps with hydronic coil backups. My DHW is also boiler fed. My current boiler (Peerless 135k btu) is located in an unfinished first floor room that is below all other floors, kind of like a walk out basement. I have a separate flue from an old wood stove that I think would serve a wood boiler just fine.
I have access to fire wood on my property and an 8 year old employee (son), and am beginning to think a wood boiler would help me greatly reduce my oil needs. I've looked into a Biomax 40 ($6,500), Tarm Solo 30 ($6,300) and Wood Gun ($7000 for carbon steel) and was wondering if any of you have thoughts about these or other units I should look into. Also, the Tarm rep spec'd the 30, a smaller unit, with the mindset that it should handle my needs 95% of the time, with the oil boiler helping out on the coldest days. This seems to make sense in that it would be cheaper up front, but also allow me to "drive" the unit hard instead of having much less btu need than a larger boiler would produce. The next size Tarm Solo was $6900.
I don't plan to do storage immediately, but thought I would add it if I was using the system as much as I intend and could justify the cost at a later date.
Finally, I keep seeing install costs in the $12-$20,000 range for wood boilers, but the prices shown above are well below that. I suppose the install and supplemental storage could be the answer, but is it reasonable that I could have a system in place (without storage) for $7500-$8500?
Thanks, in advance for your help.
- Lee
- Lee
