OK so I know it's a abrgain basement splitter but it's been working more or less flawlessly for 8 years. I was told it's a Chinese Honda clone engine, nothing in the manual about the engine at all. But this fall it started getting harder to start. I checked it out and found a hydraulic fluid leak on the big hose on the bottom (the 5 cent hose clamp that held it on had snapped). So after adding 32W hydraulic oil and multiple starts, it's getting almost impossible to start. It teries to start after about 20 pulls then starts on pull 30 lol. After it's run for a couple hours or so then shut off, 6 or 8 hours later it starts right up. Last summer I didn't notice any problems but I didn't know about the hydro fluid leak then, only that I had to top it off every 10 hours or so. I do see that the flywheel is wobbling which I was told is a bad bearing, gonna look at that first to see if it can be repaired. But the rope sticks hard for at least 10 tries then it loosens up. Reading through some threads here I saw that 32W oil is hard to get moving when it's cold. The deal is it rarely gets to freezing here so the coldest I have tried it is about 40 F. Checked the plug, carb, air filter, drained the gas & replaced the oil, no dice. Besides the wobbly flywheel (any advice on how to fix it would be appreciated) the only thing I can think of is maybe air trapped in the hydraulics? Thinner motor oil?
