blowers - are they worth it?
Ok..... not so great news. Franklin was right, the kit is marked obsolete so it cannot be ordered anymore. They said if you order TWO of the fans and the cord you have basically the full kit. All the stuff to mount it is either attached to the unit already or comes with the fans. With the prices in my computer its around $370 for both fans and the cord/speed control. The fan kit comes with two fans (one for each side) and he looked up that 832-3190 part number and that is just a single fan.
Indeed, go with a blower: alot of the folks that buy used stoves from me are extremely interested in whether or not a blower comes with. My experience with owning a Lopi Liberty, Avalon Pedelton and a Harmon Exception wood stoves are that a blower is extremely valuable in moving warm air. (broken link removed)
thanks
ck
Thanks again for all your help JP (and elk) so $370.00 for a fan kit :eek: wonder if i could come up with something a little less expensive from Grainger
The problem you are going to have is the placement of the fans on that insert. High and on each side of the shroud. Unlike any insert blower setup I have ever seen.
But I sure bet that if what was said above about the mounting hardware already being there is true that a couple of large muffin fans could be adapted to that sucker. It should be like my old Sierra insert where convection air kept the fans from harm even when they weren't running.
Thanks BB - found a muffin fan today
http://www.radioshack.com/product/i...=cooling+fan&kw=cooling+fan&parentPage=search
and attached it to the shroud everything seems great - thanks again for the tip of the muffin fan
BrotherBart said:
If I was you I would buy the blower and then order one of these:
(broken link removed to http://www.northlineexpress.com/detail~PRODUCT_ID~5SA-4008.asp)
I just put one on my blower and it works great. For $25.
BB,
Where were these when I dyked my old Buck Stoves fan by replacing the switch with a fan control unit....LOL....... good link...thanks.
