Gday all,
Looking for some advice about how best to solve an issue I’m having.
Recently had a pacific energy true north TN20 Installed in an existing fireplace.
There is a 150mm (6in) stainless steel flue that goes up the existing internal masonry chimney and outside (last 1m/3ft of the flue is also insulated).
However the installers didn’t install what I now know to be a closure or register plate above the stove.
End result is the stove just about heats a pretty small room with all the doors closed but not much else!
Reading on here and some common sense tells me I need to occlude the existing chimney to stop all that warm air from flowing upwards into the chimney breast.
So wanted to run my plans past the hearth.com elders and see if they sound like a good idea:
Going to use a galvanised metal sheet - rectangular placed just above the stove top with a cut out for the stove pipe.
Questions- what’s the recommended thickness for the sheet? What are the best materials use to anchor it in? Also - should I insulate above the metal plate as this will obviously itself get hot and I want to try and capture as much heat as possible - have seen people use things like rock wool for this - can this go right around the stove pipe itself?
I will be able to screw it into the metal lintel at the front but will have to use some sort of mortar around the back and sides.
Last question is a fan - currently the unit doesn’t have one as installer said there wasn’t enough depth in the fireplace to fit one (however can easily solve this by removing some of the masonry at the back - don’t imagine it would need to be that much as the fan only protrudes 90mm from the back and the unit currently isn’t flush with the back) - in people’s experience does this make a big difference?
Wood I’m using is Ironbark (an Australian hardwood- room temp split shows a moisture content of 18%). Think I’ve got the hand of getting the fire going alright and don’t think wood is the issue but definitely admit to being a novice and so welcome any tips on burning technique too.
