maple1
roxal with a thickness of 6" is r15
Are you sure? I was thinking it was R5/inch - so R30. That's kind of what post 18 implies also.
I found it somewhere at some point but it was like R4 per inch.To your question about Roxul breaking apart, it's easy to cut with a decent serrated knife (think bread knife, they'll typically have some of these hanging by the bags).
Safe'n'Sound doesn't have much in terms of thermal insulation, it's designed to be a fire retardant and sound barrier. I've never been able to find what it's R value is.
Safe'n'sound is more dense, with a lower R value due to less air space between the fibers.
(broken link removed to http://www.roxul.com/stone+wool/overview/faq)
Not that it matters for this application.
R15 Roxul is made for 2x4 walls and is 3.5" thick, not 6. The bag is clearly labelled.
Sterling, how'd the install go?
There are those that decide to insulate all around the insert, and while I understand the reasoning, especially with outside wall fireplaces, the I don't see a need for it as the insert I have has the outer shell.
OP, nice to see the progress. Good luck with it. Was insulating the liner discussed at all? Curious your installers thoughts on it? I would assume that some time/effort was made in verifying the clearance to combustibles on the existing chimney?
You're the customer, you want what you want. You will have to pay the extra for the insulation, but it is worth every cent. You want full insulated from top to at least the smoke shelf. Don't let them talk you into stuffing insulation around the top and bottom. Full insulation wrap, period.Maybe I'll tell them my insurance co. is demanding an insulated liner. Can't argue with that right?
