Block off plate, roxul, code?
You can use cement board like Durock Nex-Gen
It's t there any clearance requirement behind the stove or distance between top of stove and the block off plate?
I should add that there is no damper in the liner so cold air will still come down there.
No, but it's nice to have good working room above the insert to connect the liner if possible.
There is never a damper in the liner (whell almost never) for an insert. But if you close the air inlets very little air will come in. And you could always start a fire.
Finex fiber cement panel - same thing?
I'm finding it difficult to get big sheet metal. Hardware stores only sell small panels.
Do you have to use heat silicone and to what temperature must it be rated?
I haven't heard of Finex fiber cement panel, but I suspect Durock would be less expensive.
Two 2'x3' metal sheets could be pop riveted together to work. I think there is an example of this in the links provided earlier. Regular silicone is fine for the perimeter sealing.
