Bummer...bit of a learning curve with these things for sure, but the performance makes it well worth it.
Bummer...but if a learning curve with these things for sure, but the performance makes it well worth it.
I'm super glad that you have found the issue and are back in action Rangerbait. That has to be a relief. This is not a slam at cat stoves, but it reflects one of the reasons why we don't have a cat stove. They are wonderful in the right circumstance, but there are caveats and family operation of the stove is one of them, especially if everyone doesn't follow protocol.
There are workarounds, but as noted, not the only issue.Get a steelcat and vacuum it every time you do the ash. Problem solved!
That sounds like an unfair jab at cat stoves too me. The difference is so negligible that if a family member is not competent enough too operate a cat stove then I don’t see how anyone could say that same family member could be trusted to run a non cat.
I think you need to edit something in there.
So the steel cat with its smaller cells is actually causing more restriction which makes more draft in the flue? Enough difference to mimic a pipe damper at 30 degrees open vs closed tight?
That clogging is exactly what mine would look like after a few days of burning hard, before I installed the key damper. You have too much draft.
