I have a Blaze King Ashford 25 insert I had installed last year. I have a very bad creosote smell that comes in the room. We burned for two months and my wife finally said she is done with the smell. It’s very bad and to the point it burns your eyes. After a couple $500 power bills I got motivated to get the stove working again. I tried tightening up the door. I added 4 feet of chimney, putting us at 21’ of double wall pipe. This did make for a more active and easier start up. Although did nothing for the smell. I get great heat out of the stove, my wood is around 8% live oak. I can have the glass to 750 degrees in 30 minutes. The air control also works fine, I can throttle the stove down no problem. No matter where I run the stove I always get the smell.
I have another Lopi insert on the other side of my house that burns incredible. I was just looking for something I could do 12 hour reloads with.
The dealer came out last week and checked over the stove. They pulled the cat out and it looked perfectly clean. They thought I could be getting some smoke from the existing creosote build up in old chimney that the liner runs through. I did sweep the chimney and clean everything prior to the insert being installed. When the dealer came out they insulated above the stove where the old damper was, their thought was that should stop the smoke from coming down the chimney and into the house. I just had my first fire after the dealer installed the insulation. The smell is ten times worse now! We had the windows open and fans running for 10 hours and the room has a permanent creosote smell. Is there any idea where the smoke is coming from? I am thinking about ripping this insert out!
