![Blaze king questions Blaze king questions](https://www.hearth.com/talk/data/attachments/126/126853-17e89f965aac910dbfbdd8770c467f8b.jpg)
![Blaze king questions Blaze king questions](https://www.hearth.com/talk/data/attachments/126/126852-207626a238e8e11b7a0cdfb533579c36.jpg)
First I realize the big selling point for the king is burn times. I realize that on low it probably is capable of those but my question is how much heat are you getting on low settings, and also how long are burn times when it is turned up on higher settings
Secondly if my fireplace is zc but the chimney is on the outside will I have any problems putting in a non zero clearance insert ( I have measured and it will fit)
I have attached a pic of my setup and I will be moving the mantle surround if I get an insert. Thank you in advance for the input.
