Hello everyone!
I’m new to the woodstove world and looking to find out if I’m doing this correctly! Thanks in advance for the help!
Just bought a house with a Blaze King princess 32 and I’m wondering about operating procedures.
1) It’s cold here (-5 c) and probably getting much colder soon, is it a problem to run 24/7 with these stoves or should I be letting the fire completely burn itself out every once and a while?
2) Hot reloading- is it ok to do this? Obviously opening the bypass and the thermostat before opening the door, raking coals to the front and loading in dry wood. The cat temp gauge is in the active range, but after looking at several forums, it hasn’t been clear to me if this is a good idea or not.
3) I’ve had a couple people tell me, once loaded and door closed with cat engaged ,just let it burn wide open on the thermostat for 30 minutes and then turn down to desired temp range. Anything wrong with this?
I’ve read through the instructions manual on the Blaze King website, but have interpreted instructions wrong in the past. Just looking to see what’s what and hopefully have this stove heating my home for a long time.
