Well I just ordered a brush recently so it was in my mind
As I said, it was a blockage. I have deducted that it was just really wet wood that I was forced to use as I ran out of wood last year.
I probably wouldn't even bother using wood like that ever again. I'll just fire up the furnace.
I use terrible wood in my BK sometimes too. This year has been particularly bad since I did little wood gathering last year.
Burn hot, keep the brush handy, inspect the top of the flue regularly. Don't let there be enough buildup to feed a chimney fire. And be alert for that one load where you run it too low, and the cat falls out, and it smolders all the way through.... you need to sweep after that load.
If you have somebody at the house to throw in some wood every 10-12 hours, you can generally burn terrible wood hot enough to keep the flue pretty clean. (Forget about the 24 hour burns you can have with dry wood, though.)
Right now I am burning a standing dead oak that was dead so long the bark came off and the surface went punky about half an inch in. So it's soggy on the outside but pretty good on the inside... I dry the next load in front of the stove every time and it does okay. (Would be much better if I'd stacked it topcovered for a summer, but I had stuff to build last year...)
I think part of my problem with wood gathering is that I started when I was a little kid, and we knew seasoned wood burned better, but we didn't care all that much. There was no secondary burn and crumpled up newspapers for insulation, and pretty much every fire was a rager. So I am kind of programmed to think that if I run low, I can just go out back and cut some, and it'll be fine. (Which actually does work for me, but I'd save a lot of wood and chimney crud if I just stayed ahead.)
