4. Close door, let run on high 5 minutes, or until load is going nicely.
5. Close bypass, let run on high another 20 minutes.
I am with @jetsam on this one. It is confusing cause depending how cold is outside and heat loss of the house, I can be force to load before it gets that low more if am running just one stove. At that point the heat can be good for shoulder seasons but not in the middle of the winter.![]()
What's the 20 minutes for? (I understand why a stove manufacturer might choose to put that instruction in their manual, but I don't understand why you personally do it, as you know your stove and have dry wood.)
The 20 minutes is to drive moisture from the wood. Even super dry 15% fuel has 15% water! It's also cold relative to the firebox so it needs to heat up and dry out to be sure that you're feeding your cat hot, dry, smoke.
There are lots of ways to run these cat stoves that are all "good enough".
Here's my argument against: On a hot reload, with dry wood, it's gonna catch immediately. My stove burns for over 24 hours on low with a full tank- let's call it 24. My stove burns for around 4 hours on high with a full tank. That's conservatively a 6:1 ratio. So on a partial reload, 20 minutes on high may be taking 2 hours off your low burn. What benefit did you gain in return? Yes, a stove burning ultra-low benefits from a bump to cat temperature at hot reload time, but 2 minutes will get it glowing and pinging.
Discuss!
If my wood were truly dry, I’d probably be apt to skip the 20 minutes on high, sometimes. But the truth is that I’m burning darn near 100% Red Oak, stored 3+ years outdoors on pallets with no shed, in a region that has seen damn near Biblical levels of rain for 2 solid years now. I cover it in August of the year I’ll be burning it, but that only does so much.
But even if it were dry, my big old house can always use the extra kick of heat in morning or when I return home from work, after a 12 hour burn on a lower setting. It really doesn’t make a difference in room temperature, but it somehow feels good.
On the rain subject (I know... OT), my wood stockpile is at an all-time low. I’m down to maybe 10 cords CSS’d, I’m usually at 30+. It has been so wet for so long, I haven’t been able to harvest or split, without making a muddy mess of everything.
