learnin to burn said:Solar - Here are a few pics of the butterfly for the T-stat. 1st pic, T-stat is set on 1. 2nd pic, T-stat is set on high and you can see a small whole where air will still enter the stove when air is set on 1.
After looking at that picture of your set up I'm wondering if you move the stove forward on your hearth and run a diagonal length to your thimble you'll increase the length of your pipe which may increase your draft.That's how I increased my length to about five feet and my pipe runs from right to left.If it went directly into the thimble from underneath my run would be too short.learnin to burn said:Don't panic yet wet1. I split a bunch of kindling to fire the stove back up after changing the pipe around again. I was able to cheat a little buy sniping off the collar of the telescopic pipe to make it fit into the stove collar. Once that was done I was able to make the 45's work. Anyway while splitting I tested for moister content and found most of my current wood is between 20% and 27% which explains the rapid creosote build up on the glass. I'll know more about how this set up works tomorrow.
Stay tuned for the updates.
Rich L said:After looking at that picture of your set up I'm wondering if you move the stove forward on your hearth and run a diagonal length to your thimble you'll increase the length of your pipe which may increase your draft.That's how I increased my length to about five feet and my pipe runs from right to left.If it went directly into the thimble from underneath my run would be too short.learnin to burn said:Don't panic yet wet1. I split a bunch of kindling to fire the stove back up after changing the pipe around again. I was able to cheat a little buy sniping off the collar of the telescopic pipe to make it fit into the stove collar. Once that was done I was able to make the 45's work. Anyway while splitting I tested for moister content and found most of my current wood is between 20% and 27% which explains the rapid creosote build up on the glass. I'll know more about how this set up works tomorrow.
.I sell these babies and always try to burn them outside first, you need at least 3 feet of pipe and it still doesn't burn well but it sure is better than that stink in the house!RustyShackleford said:Anybody fire it up OUTSIDE, with maybe a piece of black stovepipe on the top ?
I guess that means you need your buddies there twice, once to get it off the truck,
again to move it into the house.
But all the paint outgas is outside ...
